ANGRY-ALIEN
ANGRY-ALIEN's Avatar
10.28.2010, 08:09 PM
Well, crack and peal manufacturers usually make the paper with high tack adhesives which makes it a little difficult to remove the paper from most surfaces...
if you can find low tack version (something similar to window masking), you can use it directly on the carbon... try a small piece first and see what happens
when you try to remove it...
Alien
