Thread: MM Arming Issue
nitrostarter
nitrostarter's Avatar
10.29.2010, 02:28 PM
Have you tried resetting your radio endpoints to stock and trim to 0 and recalibrating? It could be that the radio's neutral point has changed over time to the point where the ESC is just waiting for a proper neutral setting before it arms. The throttle pot could be getting dirty/worn and is "drifting".
If that's the case, grab another radio and test it out. You should be able to pin point or rule it out.
N. Rustler conversion
