Thread: Real 17mm hexes
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
10.31.2010, 09:46 PM
From this pic, which I altered a bit, it looks like those O rings go inside the nuts in a small channel that can be seen, it's where I made the red line. This is to help prevent the nut from unscrewing itself. The problem with that channel is that it take away two or three treads off the nut so it might explain why they were so easy to strip.
No brain, no headaches.
