GriffinRU
03.02.2006, 07:43 PM
Originally Posted by nitrostarter
WHen I got my 18120, it was on boat programming and it has no brakes. Its not bad once I got used to it. My output gears are still going strong. I only trashed one because my Rx pack was dying and It wasn't shifting completely.
I wasn't recommending this, just throwing it out there.
I thought you did that with Novak's HV4400 ESC...
Rtsbasic
Nice work, I don't see any real disadvantage to sensored as a technology, the products just aren't there yet though (for more than 6 cells anyway). Looks like you really know your stuff, although it is quite a bit of dead weight to be carrying.
Is that a T-Maxx chassis? How hard is it to transplant one onto an Emaxx? I guess the front and rears are mostly the same, its just the tranny and servo's i'm concerned about. I'm on too much of a budget to spend $200 on a chassis but T-Maxx ones are nice and cheap
Advantage is huge in starting torque department. Well, extra 200g for now. Later will be less (only sensor part) and Feigao motors sooner or later will be available.
It is E-Maxx chassis
But I've done T-Maxx chassis conversions earlier; it is quite simple .
coolhandcountry
ARe you running the same gear on each motor? If so what would happen if you ran different sizes?
Same number of teeth is a must, otherwise synchronization would be lost. But you can play a little bit with timing (+/- tooth or more), I will put more info over weekend.
Artur
