AL3xGR
Account Deleted
11.07.2010, 03:08 PM
If you are gearing for the same top spped with both 2s and 3s the 3s setup "should" run cooler. You will have more overall power and torque with the 3s setup, so you will want to drop the power by adjusting the punch control and maybe lowering the timing.
I ran an ste with a neu 1509 on 2s lipo and it did just fine so I can imagine this setup with 3s will work great.
But i think that the motor will overheat easier on 3s because of the higher voltage.
