ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
11.08.2010, 02:19 PM
I only meant that, unless the cells are perfectly balanced. It will always show a bit mor Mah going in on the charger than the actual battery is sucking in... Ex. I charged my battery yesterday. It wasnt balanced perfect when charging ended. So I let it totally balance out. and threw it back on the charger. The battery took in 560mah more...
Think about it like this: Say the charger is charging at 5amps. While the Balancer is working at ~650mah to balance the cells. So after an hour if the charger displays says it put in 5000mah, in reality it only put closer to ~4350mah...
Thats what I meant earlier.
I am glad to hear that is took a beating and kept ticking! Thats what it is all about!
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
