One pin
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
One pin - 11.12.2010, 09:05 AM
Originally Posted by Daleyb93 View Post
Ok great to know. So i pretty much have a turbocharged stock truck (allu bulks etc…) without the setscrew thingo will 8 ejector pins be fine to fit 1 truck?
Thank you
You can probably do all four corners with one 14" pin, but for the price I would get a few pins so you have back up spares. They are easy to cut with a Dremal tool using a cutoff wheel. I usually grind a divit into the pins where teh setscrews seat, and then you are good to go.
SUPERMAXX YOUR LIFE.
