Thread: Mp 7.5 sc
mjderstine
mjderstine's Avatar
11.15.2010, 11:45 PM
hey guys redesigned the rear lower links in my head again. too bad i spent bout $20 on parts, good thing is i can use those parts for the upper links.
Hesse machining already has these links, i would just need them shortened a bit maybe beefed up where the ball ends screw in since i use 5mm set screws there.
what do you think?
the battery trays and rear shocks were moved 12" forward to get them outta the screen shot for now.
i started drilling holes for the shock. the top line to the right was a guess. way off.
the top line on the left is just junk. it sucks. but it will work. I started paying more attention on the 2nd two lines. i kinda buggered up that first one.,
brand new shark fin for the center upper mount!!
lots of cool holes for different mounting positions. i plan to paint this flat black.
and i also did better on the set of black plates for the mounting holes for the shocks...
