brushlessboy16
brushlessboy16's Avatar
11.17.2010, 02:01 PM
Originally Posted by bigtree5476 View Post
Ok after I thought about it I pulled the center dif out , and took it apart and flipped the bearings . Is that what I should do ? It seemed to work . With the monster mount I see it has a extra piece the spacer. I have a 48 t spur gear will spacer work for that . Lmk so I can order the mount that was why I was so confused but I think flipping the bearings Did it I hope. Thanks for you quick responces
The rc-monster kit is higher quality than the losi kit. I have had both.
The Rc-monster Kit has brass threaded inserts to prevent the holes stripping out like the all plastic losi tray does.
The Newer style rc-monster mount is a single screw adjustment like the losi but much easier to remove the motor.
And Im not a fan of the tekno setup....
You keep the bearings the same, Flange side towards the diff. Rotate the entire diff 180* so the spur gear is towards the back of the car. The spacer (tee-hee I designed it) fits under the Center diff assembly.
See here:
