nastety92
11.22.2010, 10:15 AM
Nope they still have MM so I see no reason for Castle to send you a Pro... You can UPGRADE to a pro though for around $75 IIRC.
MM are one of the most robust controllers... They power a CRT.5 without any issues although for 3S it is worth adding an external BEC.
Thank you for the quick responces guys. I see the Mamba Pro has a built in BEC, would that be enough for my setup? Do you think the Mamba Pro is a good upgrade to the older Mamba Max?
I have two Mamba Max's, one has a broken on/off switch and the other does not work at all, I think I remember seeing it get a little smokey at one point.
Thanks,
Nick
