11.22.2010, 11:19 AM
On a regular MM, I would run an external BEC on anything over 2s lipo. This is because it has a linear BEC and can't deliver much current without overheating with a high differential voltage.
The only reason the MMPro needs an external BEC is because it seems a bit weak. It has a switching BEC just like the external ones, but as Arct1k stated, the MMPro bec tends to have trouble with more powerful/faster servos.
