SunnyHouTX
SunnyHouTX's Avatar
11.22.2010, 12:35 PM
Burst power from these motors is incredible... the 50% efficiency point (the point where more input power won't generate any more output power, just more heat -- those of you who run ROAR motors know what I'm talking about) is so far down the graph that we can't hit it without destroying the motors. So they can be used in high burst applications (like drag racing) just as well as oval, dirt track, etc...
I like the sound of that
These motors use .2mm powder coated laminations (expensive -- but much lower no load current -- almost all other motors on the market use less expensive .35mm laminations) oversized NMB bearings, high temperature magnets (N38UH -- good to 180C temperatures) 180C rated windings, 6061-T6 case components, etc...
These motors were designed to be as bulletproof as possible, and as efficient as possible.
Impressive! Thank you for giving us such a well designed product at a great price point.
