11.27.2010, 05:40 AM
Originally Posted by johnrobholmes View Post
I would suggest against the andersons. They do poorly in vibrations unless you use the 75a versions. I would suggest bolted eyelets, castle type bullets, or double deans plugs before power poles.
Good advice. I think I have a decent selection of 5mm or maybe larger gold bullets somewhere. Need to dig them out. Will do the bolted eyelts for the interface with the bike wiring, as I do not want to cut the factory stuff off. Thanks JRH!
