Originally Posted by Achaios
Which is the "best" one to use theoretically speaking?
The
best one would be determined by what temps you get from the esc and motor. There is also a lot of variables like battteries, climate, driving style, where you run (boggy sand through to hard top) which affect temps. Most (if not all) people have a range of pinions in their kit. If you don't already have one get yourself an IR temp gun and check the temps regularly, cheap way to look after your gear.
