Unsullied_Spy
Unsullied_Spy's Avatar
11.29.2010, 02:28 AM
You should look over your car and see if there are bind points. Gear mesh too tight, bearings going out, etc. It shouldn't be getting hot like that. I'd check the car beginning to end before wasting any more money on fans.
The label on that fan should be up, judging by the shape of the blades it is set up to blow air down into the heatsink.
