11.29.2010, 12:57 PM
What size is that lipo pack that was tested- kinda difficult to tell / determine the voltage drop per cell & generate some actual c ratings without knowing it; 32.3v starting voltage is odd...
Imma pretend that its an 8s lipo pack ( seems if 32.3 / 4.2 = 7.6s, and its several minutes into the run, so... ) for the purposes of this post:
8s lipo = 33.6v
minimum voltage recorded is 27.6v, so thats 3.45v per cell ( minimum voltage, under maximum load )
The highest current ( load ) recorded is 178.1 amps
So, 178.1amps / 6.5amps ( 6500mah lipo ) = 27.4C @ 3.45v per cell
Thats pretty shockingly bad considering these are rated for 75C @ ...3.2v per cell say? ( since MA dont specify the cell voltage held under the 75c load ).
Well, there you go, more false claims by MA, what a suprize.
