11.29.2010, 01:34 PM
Ehh dropping to less than nominal voltage
Going by the max wattage (assuming that max amp draw coensides with the lowest voltage)
3958/30.0= ~132amps.
30/8= 3.51v per cell if I have you setup correct
What are these cells rated for?
kids today 30/8 = 3.75V @ 135 amps
they are 6500mah packs which probably means 6000mah usable i.e. 135/6000 = 22.5C spike
