brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
11.29.2010, 05:09 PM
Great! I will give that a go once the truck gets here. Too bad Castle seems to be ending their clearance? http://www.castlecreations.com/promo...clearance.html
It says they are having technical difficulties, which, I assume, means they are changing the page. I really hope they still have those motors on sale. I'll probably have to stick with my 9L if I can't get a decent motor for under $80ish.
I have a large 4700uf 35v capacitor that I had plugged into the spare RX channel, but would it be better served on the ESC? And if so, should I solder it right to the board or somewhere on the battery leads? I also have a 40mm 12v fan that I could put on the ESC, so I might do that.
Thanks for the help!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
