Originally Posted by MindThoughts
Note: Brandon- do you think based on the information I provide- I could run 2 6500mah 3cell 150c lipos(in series= one six cell)in my Brushless E-Revo wide open across the entire park which is about the length of three football fields length wise? Without puffing the LiPo's? I've modified the battery boxes so the 3cell 6500mah lipos will fit right in. I just need to know if you think these lipos can handle apx 125amps being drawn from them over the course of apx ten seconds, and then turn around and do it again and again until the lipos are at the 3.5volt per cell LiPo cutoff point- or just before the LiPo cutoff kicks in? Thank you Brandon. I very much look forward to your response.
Yes our 150C packs can handle the load. We have tested them at a higher amp draw then that.
Brandon
