sikeston34m
sikeston34m's Avatar
12.01.2010, 06:47 PM
That battery brick, if in 4s config, must be something like 4p or 5p judging by the size. I'm going to have to call shenanigans on this one...
Let's say that pack is 4S5P using 5000mah cells. Let's also say it was created using 10C cells.
We have 25000mah of capacity capable of 10C. That's 250 amps continous with 375 amp bursts.
Since our voltage is a big higher than usual compared to a lead acid battery, the extra voltage will help the starter turn faster.
A 10C pack in this configuration will do the same thing as demonstrated in the video.
If the truth were known, they probably were 10C cells.
I'm not impressed AT ALL by this, since once again, the configuration is NOT revealed. The capacity is NOT REVEALED.
I'm ALOT more impressed with this video.
"Here's another battery cranking video - with one 4000mah 3s pack.
http://www.youtube.com/watch?v=WkKRqaNPIBE"
No BS with this one. Nothing hidden. The configuration is 3S1P and the capacity is 4000mah.
Ummm........Brandon. What is the pack configuration and the capacity in your video?
On second thought, I bet I don't get a freaking answer. Questions like this don't get answered because EVERYTHING is fudged!
