Darren
12.02.2010, 08:38 PM
Originally Posted by Dj_Sparky View Post
Try disconnecting the servo, try another receiver and radio, and go over the wires to make sure its all connected tight and right.
Checked everything just now, everything's connected fine. Tried disconnecting the servo and still had the same problem.
Originally Posted by josh9mille View Post
It almost sounds like there is a pebble in the gears or something
I don't think there is, everything's sealed and if you put it on a single 6 cell pack, the wheels will spin consistantly as long as you give it 60%+ throttle.
I'm starting to think that the ESC is at fault and I should just return it to get replaced under warranty? Also the front bulkheads have a few 'holes' in them. Like there has been bubbles in the plastic moulds , interesting.
