E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.03.2010, 12:38 AM
Originally Posted by Darren View Post
Checked everything just now, everything's connected fine. Tried disconnecting the servo and still had the same problem.
I don't think there is, everything's sealed and if you put it on a single 6 cell pack, the wheels will spin consistantly as long as you give it 60%+ throttle.
I'm starting to think that the ESC is at fault and I should just return it to get replaced under warranty? Also the front bulkheads have a few 'holes' in them. Like there has been bubbles in the plastic moulds , interesting.
I had a "hole" in my front bulk too. I figured out what it was for though, just before I sold it I had to replace the front diff. There is a long screw that you access through that hole after you pull the suspension pin out
