snellemin
2 KiloWatt RACER
snellemin's Avatar
12.03.2010, 11:52 AM
I'll post this info here too.
The Bigmaxx is a 1800W 2300kv motor and about the same length as Castles 1520 motor. It runs on 4s Acepow. The other Pletty that I blew up was a 1000W 3000kv motor.
The Bigmaxx has too much torque and I'm actually considering using the current limiter. 1000W or like most 1512 motors are perfect for the GTB.
Motors that I have used in either GTP's are:
Hacker C50 13L 1874KV and 6L 4060kv motor (As smooth as sensored and perfect amount of torque w/quick spoolup)
Plettenberg Maxx 3000kv and Bigmaxx 2300kv motor(4 pole motors that spool up like a 2 pole)
Castle 2200KV and 1520 1600kv motors(both are torque monsters, but slower spool up)
Tekno Neu 1512 1400kv motor(Way smoother than Castle motors)
Tekno Neu 1515 2700kv motor(Fast smooth torque monster)
Tekin 4030 1400kv motor(Even smoother than the Tekno Neu)
Lehner XL Basic 3100kv motor(Tough little motor, but an XXL would've been better)
Hacker C50 Maxx 14.4 3600kv motor(Same can size as the C50-L motors, but less torque due to shorter rotor magnet)
LRP 2500kv 1/8 motor.(13mm rotor just doesn't cut it. Worked well in lighter vehicles. Power is equivelant to a C40-L Hacker motor)
ESC's that I've run in the GTP's:
Losi 1/8 ESC(Ran 6s A123 with Tekno neu 1515 2700kv motor. Blew up after firmware update)
Lutach LT-10s 120A(10s A123 is overkill with a 1400kv Tekno neu)
Tekin RX8 with cap bank(favorite)
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
