12.03.2010, 10:30 PM
Pretty sure its standard 25mm spacing, also pretty sure it uses M4 bolts for mounting.
I wouldnt worry about the home-brew 6mm > 5mm shaft, so long as there is no slop in the pinion on the shaft, and the shaft is uniformly 5mm ( not shaped little skittle at a bowling alley )...
