Originally Posted by Overdriven
I like to mount everything closer to the front. I've found it helps increase steering, especially on power. Then again I like alot of steering because I like getting sideways.
I thought the same thing. I have always liked to put the weight over the front tires as much as I can, as it seems to help steering, especially under power. You do have to use a stronger steering servo, but I have quite a few jr 9100t servos.
I also will run mech brakes, so I will need to mount the brake servo somewhere, likely just in front of the center diff on the motor side.
Pics will be up tomorrow, had pc issues all day today at work...
