12.09.2010, 11:43 PM
Ok, I am not quite with it today.
For some reason I thought I could swap the steering bellcranks and put the servo on the other side...WRONG
So I got the motor out of the flux, set it up on the same side as the steering servo, and found some small pinions, 18/22, for the 2 speed adapter. It all fits, with room to slide the motor over for the smaller 16/20 gearing I need to order.
Also, the brake servo will fit behind the steering servo and in front of the centerfront bulkhead. So good to go. Battery fits a little better on the opposite side, and the MMM looks lost behind it. I do need to figure out some sort of tx/bec mount or box.
Only issue is that the rear brace off the rear diff bulk will need to be moved to clear the motor. Looks like I can swap in a longer turnbukle and run it slightly diagonally and mount it on the other side of the rear center driveshaft.
Forgot to take pics but will do that in the morning.
