Wildjones
12.10.2010, 02:02 AM
I can give you some more info if it will help....
The blue wire is negative, the white is the balance wire, and red is positive. I have never seen a single charge wire except on this battery hence why I am confused. The female end of the connector plugs straight into the chassis of the helicopter. I am trying to do the least amount of monkeying around so as to not mess up the balance of the bird...
I dont know if its cool to post links to other forums, but I saw a guy who made a new battery by using the jst plug outputs like they should be, then somehow combined the balance wires to one wire and connected it to the white wire. Heck ill just link to the single post. If I need to remove the link I can always do it later: http://www.rcuniverse.com/forum/fb.asp?m=5257799
It seems like he got away doing it just fine, I just dont know how to go about combining the balance leads. I dont know if its cool to just solder the two together and call it a day or will it short out the pack, must like touching the 2 jst wires would?
