Thread: New guy here!
pmike33
pmike33's Avatar
12.11.2010, 05:59 PM
Welcome to RC-monster, Mike, you'll like it around here, its a tight-knit group with some real weirdos/ characters
So far as BL systems go, the 'best' depends on what it is you want from the system and how much you are willing to spend; Castle systems ( MMM & MMpro ) do really well in anything MT and 'uggy shaped, but so too do the sensored Tekin systems- pretty equal specs so its a bit of a personal preference thing that you arrive at from using both systems usually. Tekin does have the advantage of a wider range of motor kv choices, though the castle motors are more powerful by most accounts- you'll see people using MMM escs and tekin motors quite often so I wouldnt get too hung up either way.
As for chargers, there are a fair few dual-channel lipo chargers that can do two lipos at once without the need for a home-made wiring harness:
http://www.allerc.com/hyperion-eos-1...0w-p-5962.html
http://www.allerc.com/hyperion-eos06...er-p-4632.html
http://www.commonsenserc.com/product...oducts_id=2229
http://www.revolectrix.com/10s_description_tab.htm
http://www.rcaccessory.com/bantame-s...pocharger.aspx
http://www.gonitrohobbies.com/TENERG..._DX_p/1250.htm
http://www.hobbycity.com/hobbycity/s...dProduct=11170
http://www.hobbycity.com/hobbycity/s...dProduct=10327
Most of those will require a separate powersupply too- there is a nice tutorial that shows you how to make your own cheap & powerful supply:
http://www.rc-monster.com/forum/showthread.php?t=27554
Thanks for your welcome.
I just plan on using it at home, and maybe sometimes using it in my truck when I stop by the local track. So Ill need AC/DC use.
Ive got alot of reading and researching to do also, I started looking at all those links and got alil overwhelmed!! I will read that write up on the homemade power supply as well.
I appreciate the help so far, this whole lipo deal is new to me, I swore I never was going to do it because of when they first came out I read alot of horror stories about fires etc. But Ive also heard they have come a long way since than, plus my buddy has been into this for about 4 months with no problems.
My buddy is using the Passport lipo charger by Dynamite. It only charges a single battery at a time. He suggested to but two of them since their only 65 each. I personally rather have just one that does two. But I don't want to buy one thats not quality and have a potential fire.
Anyways, thanks again for your help so far. I will do much more reading on this and figure out which one is good for what I plan on doing.
