Imo -
12.12.2010, 12:15 AM
For shock towers, probably 4-5mm is good. For a chassis it depends if you want to do a single plate or a double-deck thing. For a plate chassis I'd use at least 4mm. If you went with the double-deck then 2.5-4mm would work depending on the design and your intended use.
