Thread: Nose up?
reno911
Smelly Nitro meet your maker!
reno911's Avatar
12.12.2010, 01:52 PM
Practice your let off timing. By the video it sounds like your not letting off the throttle at the right time. In other words your still throttling through out the ramp into the jump. There were a few times where you got it just right and at least it appeared that you didn't brake. I don't think you need to rearrange your susp it looks like that is pretty dialed. Just practice on the timing of your finger to jump. You should be able to get the right amount of throttle to clear it without having to gun it into the ramp so that your nose goes up as if to do a back flip.
Trust me if I goof before a jump and I have to basically gun it to clear something I look exactly like you. Straight up. But if you don't need to gun the jump you should be able to get the right speed and just let off sooner to clear it level.
