thzero
12.12.2010, 08:58 PM
16lbs? Mmms... really? My Savage 5T conversion is 16.4lbs with a 2200kv and 5S. So I can't imagine this thing would be less than 18-20lbs. Granted they are saving a bit of weight with not having beadlock wheels...
4S/6S? With a 1150kv? SLOOOOOOOWWWWWW. If indeed its at 16lbs, 6-8S, should really make it rip.
Axles look whimpy. I'd rather seen 24mm hexes so you could easily run Baja tires/wheels if you want. This would probably be the reason I'd avoid it that and from the look of it, none of the adjustments you can do on a buggy/truggy. Otherwise looks good especially for a 5th scale RTR.
