ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
12.13.2010, 01:45 PM
Mr. Crash, You would be able to tell me the Distance between the Stock holes on the Axle? From where the CVD Pin goes through the axle to where the Hex Pin goes through the axle? And distance between the hole you drilled in the axle and CVD Pin hole.? And Lastly. Length of your CVD Pin to Pin. I have been tinkering with some 17mm Hubs and 8mm Axles. I appreciate your time...
Thank You Sir...
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
