mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
12.14.2010, 11:29 AM
I measured the axle from pin to pin to be 136 mm. From the axle pin to the hole I made I measured 20 mm. I use a 2 mm aluminum shim behind the hexes to keep them away from the bearing. It's the shim that goes between the two bearings of the pinion in the LST diffs.
No brain, no headaches.
