Manne
12.15.2010, 06:45 AM
Do the Lst diff mod. Stock diffs won´t last a week on 5s with those tires, neither will the driveshafts. You should take a look at Mistercrash Thread.
You could either use summit shafts or modify Lst cvd´s to fit. I would re install the rollbar and reroute the wiring from the spurgear. I would also mount the esc on the rear shockmount instead so it sits lower.
Nice build! Good looking!
