rchippie
rchippie's Avatar
12.16.2010, 02:47 PM
You need to work on your Drafting. By doing this you save any were from 20% - 30% of your energy. Also when it's your turn for a pull at the Front. Try & keep the same pace as when you were Drafting, & don't burn your self out trying to do a long pull. If you can only pull for a mile or so that's fine. Also be sure to signal the rider behind you before you pull off, so you your pace line doesn't develop a gap . Most people do this by tapping there right hip a couple of times to let the rider behind you know that your pulling off. Your new bike looks good.. I will look at the pics better when i get home from work.
REAL MEN RUN BRUSHLESS
