Pdelcast
Pdelcast's Avatar
12.17.2010, 01:18 PM
Originally Posted by johnrobholmes View Post
Thanks for the detailed info. Good enough for me :D
So what is the controller and shunt resistance of the ICE HV 160 (no wires)?
360 microohms for the FETs, and 125 microohms for the shunt. Copper resistance is around 50 microohms.
~22 watts total I^2R controller losses at 160A. (or approx .45 watts per FET) This doesn't include switching losses. Switching losses depend on the commutation speed of the motor -- but a good "middle of the road" estimate is approx. 8 watts of switching losses at full throttle. (Partial throttle switching losses are higher -- because the PWM losses are combined with the commutation losses.)
At 50V, 160A, full throttle, this gives an efficiency of ~99.63%
(note: the losses on the controller is about the same as the losses in the ~25" of 8ga wire attached to the controller... 8 ga wire is approx. 600 microohms per foot -- total losses in the wires at 160A is approx. 32 watts... and the numbers are even better on the ICE-200 and MM-XL, because the FET resistance is only 213 microohms...)
Pretty damn good, I think.
Patrick del Castillo
President, Principle Engineer
