sikeston34m
sikeston34m's Avatar
12.18.2010, 10:37 AM
Something I'm playing around with here lately is:
Leave the pcb inline to protect the cells on the pack, then use a dc to dc converter to adjust the output voltage to match whatever is being powered.
Small dc to dc converters are pretty cheap. I just bought a 3 amp unit off Ebay.
It's specs are:
Input Voltage: 3-30VDC.
Output voltage: 1.3-18VDC.
Max output current: 3A.
Built in LM2596S-ADJ.
Compact size. (about 1 1/2" x 1 1/2")
For lighting, this would be a great thing.
It has a pretty wide input range. (as low as 1s or as high as 7s)
I'm thinking it could run a large amount of Led lighting in the event of a power outage.
