Another question for Patrick...
ta_man
Another question for Patrick... - 12.19.2010, 12:44 PM
1410 motor has a 1/8" output shaft and I believe you mentioned that this was for ROAR requirements. I didn't take the motor apart to measure it but the bearing looks like it could accomodate a 5MM output shaft. If you offer rebuild kits for the 1410, would there be an option of a 5MM output shaft?
I have no concern about the 1/8" shaft in a car with a slipper, but in a CRT.5/SCRT10 or similar car with direct drive and exposed gears, I would be concerned that a stone in the gear could snap the 1/8" shaft (actually heard 2nd hand reports on RCTech of people snapping these shafts). Then you would have to replace the rotor anyway, so why not do it right away with a 5MM output shaft rotor?
