sikeston34m
sikeston34m's Avatar
12.20.2010, 12:15 AM
Well, I would take a copper plate, draw a grid pattern with the lines spaced the diameter of the cells. Punch 1/4" or so holes where the lines intersect and solder the cells thru those holes. Wrap the packs of 30 cells in something that can be removed, such as large shrink, then place them in a waterproof box of some sort that has padding (closed cell firm foam?) on all sides and between each pack. Wire the packs in series with large gauge wire and add a balancing tap for testing purposes.
How much did those cells cost and where did you get them from?
This has been what I've been thinking about doing. My first thoughts were solder to copper plate. But then I thought.........
By doing it this way, it's going to be pretty hard to disassemble should the need arise.
Today, I took an old 18650 cell and soldered a galvanized screw to it. It's a counter sunk type machine screw.
What if I soldered one to each end of every cell. Then installed all the cells to the plate with lock washers and nuts?
This would make wiring hookups very easy and also make the pack easy to take apart. If the need were to arise.
On the copper plate, I've noticed that stuff is pretty spendy. I wonder if 1/8" aluminum plate would work? Afterall, aluminum is pretty conductive and it is used in the aerial cable that feeds our home. Would resistence be a factor if 1/8" aluminum plate were used?
Foam padding. A good idea!
I'm thinking of building an aluminum box to house the pack and the converters. I can caulk it up to make it resist water, plus it will be a natural heat sink.
This would also serve as a nice power station to use with an AC inverter.
I lucked out on the cells. You're looking at $150 bucks worth of cells plus shipping. It was a liquidation sale. I have tested samples. They do go full capacity.
