sikeston34m
sikeston34m's Avatar
12.20.2010, 09:40 PM
Originally Posted by johnrobholmes View Post
Do you have a low voltage monitor on the pack planned as well?
No matter what you will be looking at a massive pack construction task. The cell body needs to be supported while keeping the connections flexible. I would suggest building smaller parallel chunks of cells that you can gang together in the case that pack work needs to be done.
I like your idea of doing it the other way with the screw on the cell. Just don't support the cell by these.
The only type of BMS that I have planned at this point, is a digital display monitoring all 6 cell "regions" of the pack. I will consider other options, but I don't like the BMS circuits that I've seen so far, as they generate a small amount of constant drain to keep an eye on things. The pack will be unplugged when not in use.
One other thing I wonder about is: the input range of the converter array is 18 volts to 36 volts. I have to test this, but if the converters bail out at 18 volts, it would be perfect! 3.0 volts per cell would be a good low voltage cutoff for this.
The connecting endplates will be smaller than the brick. No weight will be supported by these. The cell walls will be it's strength.
After a full day of fishing with my wife, on a trolling motor only lake, I measured with a watt meter how many amp hours the charger returned to fully charge the lead acid batteries we used that day.
You might be surprised. It returned 30 amps hours to the lead acid batteries.
I'm sure this figure is off some, since alot of energy toward the end of the charge is spent "gassing" the cells in lead acid to top them off with that last 10% of the charge. Lead acid has less useable capacity than lithium ion.
