bigsteel
12.22.2010, 04:32 PM
My baja is a clone but 99% has been switched to upgraded parts.so if you want something cheap to drive and are going to put hop-up after hop-up it's worth it.
They do use something in the 4 series of aluminum,I found that out when I tried to de-anodize the smaller parts and they lost half there mass in 30 seconds! But I'm still running a completely stock drivetrain with NO wear,not even on the drive cups with a DS 26.5 ported marine motor, and I've seen real bajas drivetrains fail. So it seems like they skimp on good aluminum,but the steel I definately up to par. Oh,and all the plastic is a non fiber reinforced stiff type that I couldn't quite pinpoint.--josh
