bdebde
That's All Folks!
bdebde's Avatar
12.26.2010, 02:59 AM
Very interesting. No idea this existed. What exactly does the reverse pulse do? Similar to the welder method?
Not sure I completely understand why the welder method is used with both reverse and normal polarity. Semms like the reversed polarity would discharge the pack, and the pos would recharge it... Not quite understanding which way breaks up the crystals... Need someone with more knowledge of dc to explain this to me...
From the Tekin manual
Normally a cell will noticeably begin to lose its edge and crispness to throttle
response after just a few hard runs. This is caused by a gradual buildup of impurity
nd crystal formation inside the cell, which is unavoidable. With each run the impuries
increase, resulting in increasing internal resistance, and therefore reduced voltage
nd power output. Discharging the battery fully after each run will help reduce this to
certain extent, but the only way to totally minimize this deterioration, and even actuly
reverse any previous deterioration, is to use the TEKIN Power-Flex process.
wer-Flex makes your batteries perform like no other charge process can, and
creases horsepower beyond what even a new fresh cell could deliver.
The Power-Flex circuit is a refined version of the Pro-Flex circuit introduced by
EKIN in 1989. Power-Flex works by periodically turning off the charge current, and
pplying a short-duration, high-amperage discharge pulse of negative current to the
attery. This so called “burping”of the battery acts to relieve the pressure buildup which
ccurs inside a cell during charging, and to restore its chemical balance. The net result
that the cell stays cooler during the charging process, and delivers more voltage and
apacity under a load. With the BC112, the amount of Power-Flex conditioning that
ccurs is computer controlled.There are three user-settable levels.
