glassdoctor
TEAM FUSION
glassdoctor's Avatar
12.26.2010, 01:30 PM
Short answer... cycle them 2-3 times and see what you get. If results keep improving, keep cycling.
1-2c charge.... discharge however high your charger will do if these are good sub-c cells. 10 amps if your charger can do it.... or 20+A if you can get your hands on a Turbo30
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
