ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
12.28.2010, 12:04 AM
Photobucket
I will add these braces. 1/4"x1/2"x2". They screw into the FLM Braces through the chassis. I still need to tap the end and screw the motor mount to the end. Then I will make an angled piece of 1/8" 7075 to finish it off and make it rock solid.
Here is what I got up to now (minus the 7075 angle and screw tapped in from the motor mount side)
Photobucket
Photobucket
Photobucket
About ~2mm off the motor fins to the chassis: Woot! Even if I regear to the 50t spur and I can lower the motor down again to keep the motor sitting nice and low...
Photobucket
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
