12.30.2010, 12:40 AM
Oh I know what you're thinking. I've had the same idea in my head for awhile, only difference is I have a bunch of maxx parts and a 1520 to put to use.
My only issue with maxx parts is the relative lack of strength. Howver if you were to make your oven metal bulks, use rpm arms with the hd front knuckels and a true track rear szetup and something like an 1/8 buggy steering setup you would have a light weight suspension. Couple that to a carbon fibre chassis (U shape and thick-ish) and you may be able to keep the weight way down.
I had planned to use 40 series wheels/tires for the rear, and the lpr truggy tires and wheels for the front to give the narrow/wide buggy look. The boddy of the XLB is boxy, and I think it would look good that way.
