12.30.2010, 12:55 AM
Originally Posted by josh9mille View Post
Ya thats a point, but honestly who uses anything less than 5000mah in a monster truck anyway?
Depends on the voltage. If you were looking for the same total output (watts) a 5000mah 6s pack would work as well as a 12s 2500mah pack...
And weigh the same. Size might be a limiting factor, unless the 2500 mah cells were slimmer, but given the same C ratings the cells are often about the same thickness, just smaller in other dimensions.
