12.30.2010, 01:49 AM
Originally Posted by tommyheadleycox View Post
On the contrary, this is a huge help. The available literature was confusing on how to calculate the modulus. This url converter is a big help. I knew that the modulus was close to 0.6. But it's better to know that it's exactly 0.58. That's of course assuming the original diameter was 7 mm. But if it was 7.5mm, then I know that the modulus is 0.63. If I need to, and if they're available, I can order pinons in 0.58 and 0.63 modulus.
Again, many thanks,
Tom
Cool, glad it might help. Along with just the pitch/modulus, also pay attention to the tooth geometry (pressure angle), as there can be variation there even with identical pitch gears. I have a feeling a very large/detailed picture will be needed for sdp-si to make sure they provide the exact match.
