How?
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
How? - 12.30.2010, 06:48 AM
Originally Posted by supralover72 View Post
The Baja was designed from the ground up to be 2wd. I feel like it's more than inferior for 4wd. If you want 4wd and 1/5 scale why not just an FG modelsport or something similar? Why waste all that money and parts for and inferior system?
How would you figure even in the least that the 5b would be a bad 4X4? First off it is a rail style buggy, which in the world of a 1:1 are in a lot of cases 4X4. The 5b is in my eyes the best looking 1/5th scale R/C buggy being made, and with the way it is built can take a lot of punishment. So why would anyone want to go for an inferior design as an alternative. Converting any vehicle from 2wd to 4wd creates a less efficiant power curve, but the trade offs in basic handling are usually well worth the effort. If you put a 5b 2wd up against a 5b 4wd with the exact same powerplant, which one do you think will prevail? I would take the 4X4 any day.
SUPERMAXX YOUR LIFE.
