Originally Posted by tommyheadleycox
On the contrary, this is a huge help. The available literature was confusing on how to calculate the modulus. This url converter is a big help. I knew that the modulus was close to 0.6. But it's better to know that it's exactly 0.58. That's of course assuming the original diameter was 7 mm. But if it was 7.5mm, then I know that the modulus is 0.63. If I need to, and if they're available, I can order pinons in 0.58 and 0.63 modulus.
Again, many thanks,
Tom
The Duratrax Vendetta 1/18 RC car uses Mod 0.6 pinions if I remember correctly, but I believe the stock bore is 2.3mm. Might be worth a try looking at those
