bensf
01.01.2011, 04:13 AM
maybe the newest firmware is making it hard for you to use a 4s lipo cutoff because the Mamba Max is only rated to 3s
It has 12v as one of the options, and I tried setting it to 6v and it still didn't work. It worked fine if I turned off the cut off though.
I just bought a MMM though so I will be using that until it needs to go in my revo. I feel like there are just too many issues with my MM (maybe its permanently broken) and the BEC doesn't work. Thanks for the help though
